Activity Forums Apple Final Cut Pro Legacy In the market for a dv deck. In need of suggestions…
  • In the market for a dv deck. In need of suggestions…
    Posted by Danny Greer on August 23, 2006 at 1:33 am
    I’m in the market to buy a dv deck. I run final cut pro.
    I have experience using a Sony dsr-11 and have had great success with it, but it is unforunately out of my price range to buy for myself. Can anyone make a suggestion for a good dv deck (minidv only would be fine) that is reliable and under 500 bucks. Does such a thing exist?
    dg
    Walter Biscardi replied 20 years ago 4 Members · 3 Replies
  • Kevin Monahan
    August 23, 2006 at 1:45 am
    If you want to run with the big dogs, you gotta pay to play. DSR-11 is the minimum you should have as a pro. Sorry for the reality check, bro.
    In the mean time, use a cheap camcorder. I like the panny’s.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Rennie Klymyk
    August 23, 2006 at 6:32 am
    Get a sony GV-D300 or 900 (with screen) off ebay. They are small and portable and should be available used for your price range. Sony also has a newer DHR-1000 too. These units have rca audio i/o and composite, s-vhs analog video i/o and digital firewire i/o. (same as dsr-11)
    “everything is broken”
  • Walter Biscardi
    August 23, 2006 at 10:58 am
    I’ll second Kevin, DSR-11 is the only real reliable deck out there. I would not run an edit suite with any other DV deck.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
