Activity › Forums › Apple Motion › In the hole, using Motion 3
  • In the hole, using Motion 3
    Posted by Mark Suszko on March 1, 2010 at 6:01 pm
    Clent threw this one at me: make a plane surface with an infinity backdrop, picture a shot of flat desert and the sky beyond. I can do that. Now, client wants a hole or gap or canyon to open up in that flat desert floor. What I’m thinking is a lot of keyframing, using an intial “ground” plane plane (made in photoshop) with a triangular chunk missing from it, (trianglular to kind of force perspective more, though this will be in 3-d) and two triangular fill-in pieces on a separate layer that would match the “bite” taken out of the initial ground plane image. Using keyframing I can have those fold down like trap doors and maybe throw some kind of particle dissolve effect at them to make them look like they are collapsing into chunks, falling away. Another image plane below the first one, set at 90 degrees like the backplane of the “sky”, would then be revealed to make the camera-facing part of the “chasm”.
    This could take me a while 🙂
    Is there perhaps a better or easier way to tackle this kind of setup?
    If I was in a CG program I think I would use a displacement map to punch the hole, but Motion 3 is new to me. Thanks for any suggestions.
    Mark Suszko replied 16 years, 7 months ago 3 Members · 5 Replies
  • Stephen Smith
    March 1, 2010 at 7:11 pm
    Sounds to me like you are on the right track. The Particle Metrix may be of help. Take a look at this tutorial by Zak Peric: https://forums.creativecow.net/readpost/170/862717
    Utah Video Productions
    Check out my Motion Tutorials
  • Zak Peric
    March 1, 2010 at 7:34 pm
    Thanks Stephen for providing the link to my tutorial.
  • Mark Suszko
    March 1, 2010 at 8:21 pm
    And this will work on any graphic element, not just text, right?
  • Zak Peric
    March 1, 2010 at 9:17 pm
    Yeas of course it will. If you need something else like a cutout of a mountain prepare this in photoshop and save it with alpha (if needed) in .psd format.
    I hope this helps….
  • Mark Suszko
    March 1, 2010 at 9:55 pm
    Dziękuję bardzo! 😉
    I’m off to try and make this work.
