Activity › Forums › Boris FX Particle Illusion › In SE Particles Don’t Show On Playback
  • In SE Particles Don’t Show On Playback
    Posted by Kerry Cramer on July 3, 2009 at 10:12 pm
    It seems that after I put in an emitter (as per directions), the only way I can see the particle effect is to start then stop the playback in quick succession. Then I get a still image of the effect…but even that only works ~20% of the time. What am I doing wrong? (The demo did the same thing about half the time.)
    Kerry Cramer replied 17 years, 2 months ago 2 Members · 2 Replies
  • Alan Lorence
    July 6, 2009 at 2:03 pm
    I’m thinking this may be an OpenGL issue. You’re on Windows, right? Use the “run with software rendering” option in the Start – Programs – particleIllusion 3.0 – troubleshooting menu.
    If that works, then you need to download the latest video drivers from your graphics card manufacturer’s website.
    Alan.
    http://www.wondertouch.com
  • Kerry Cramer
    July 7, 2009 at 2:05 pm
    That seems to have solved the problem…Thanks!
