Activity Forums Apple Final Cut Pro Legacy In regards to sending quicktime to protools
  • In regards to sending quicktime to protools
    Posted by Mervyn on November 30, 2005 at 7:06 am
    Thanks guys for ur tips. However thats what we do here too. But it takes too much time to compress the video. I use compressor on right click of the sequence i want to send to protools. And set it to dv pal, 25 frames, video quality least. But it still take 30 min to compress. So my question is, is there a better and faster way of compressing my video of my timeline to quicktime for ref. And pls tell me how to do it step by step.
    I also did try, export – compress using quicktime. Setting to dv pal, least quality, 25 frames. That took me 12 mins. But protools can open it and view it. However, the vo monitor cannot view it. Dunno y.
    So if there is anyway of compressing it to quicktime such that vo monitor can view it that will be great. Pls do tell me the steps. One by one pls very new to this FCP stuff. THanks guys…
    From mervyn
    Andy Mees replied 20 years, 9 months ago 2 Members · 3 Replies
  • Andy Mees
    November 30, 2005 at 9:07 am
    are you using the mojo to route video to the vo booth?
    if so you might want to try using the Avid DV codec … you might find that one more compatible
    export – compress using quicktime, setting to Avid DV pal, least quality, 25 frames etc
    you can get the Avid DV codec as part of the free Avid package available on their website
    hope it helps
    Andy
  • Mervyn
    December 1, 2005 at 3:23 am
    Yes we are using the avid mojo to route to the monitor. And thanks may i know what website to get that avid quicktime thingy
  • Andy Mees
    December 1, 2005 at 6:09 am
    go to http://www.avid.com and follow the links to Avid FreeDV for MacOS X … i believe you have to register to download it, then install it …
    if you wan’t send me an email to andymees@startv.com and i’ll send you just the codec
    (which you can put into YourHardDisk/Library/Quicktime)
    cheers
    Andy
