Activity Forums Apple Final Cut Pro Legacy In & Out Points
  • In & Out Points
    Posted by Andre James on May 30, 2005 at 3:20 am
    I’m trying to capture a bunch of offline files into high resolution. The problem I’m having is that the files have different (media start/end points) than their (IN & OUT points). When I try to batch capture these files, the computer uses their (media start/end points). I need to just capture the (IN & OUT points) because they are much smaller and they are the only time of that clip that is used in the timeline sequence.
    for example:
    interview.mov – has a 1 sec IN & OUT Point (00:34:54:00 – 00:34:55:00)
    – it also has a Media Start and End of 5 minutes ( 00:32:00:00 – 00:37:00:00)
    When I try to batch capture this file (with other just like it), it tries to capture the whole 5 minutes, but I only need the one second to be captured, because that’s all that is used in my overall sequence project.
    Any help would be much appreciated!
    Jooser
