Activity › Forums › Creative Community Conversations › In FCP7, image size changes when importing one project into another.
Posted by Les watanabe on December 2, 2024 at 2:05 pmIn FCP 7 has anyone encountered this? I made 2 separate projects; then I try to copy and paste one project into the other, but all images come out so big that I have to image/wireframe each image in video and resize it to match the other video.
What to do?Thanks
Leswatanabe2
Brie Claytonreplied 1 year, 9 months ago 3 Members · 7 Replies
Devrim Akteke
December 2, 2024 at 3:08 pmOh my, there are still people who use my beloved FCP7. I went to FCPX immediately when it was published, and after one year, I never used FCP7 again. It was my favorite editing software, but it is FCPX now. For your question, as far as I remember, there is an image scaling section in project settings where you set it as fit, normal, untouched, or something like that. You may want to check there and try copying again.
I hope it works.
Les watanabe
December 2, 2024 at 11:42 pmHi Devrim,
Thank you for responding to my query! In FCP 7 do you remember how to locate Project settings?
Les
Devrim Akteke
December 3, 2024 at 7:59 amWhen you right-click or control-click a sequence in the bin you can access it through Settings and Timeline Options as far as I remember. It should also be under the Sequence Menu in the bar when a timeline is active.
Les watanabe
December 4, 2024 at 2:48 pmThanks Devrim,
I’ll have time to look at it tomorrow in pm.
Much appreciated!
les
Les watanabe
December 5, 2024 at 1:51 amThank you very much Devrim! You’re a Genius!!!
You saved me so much work!! Im indebted!!!
Les
Devrim Akteke
December 5, 2024 at 7:55 amIt’s great to hear that helped. Always a pleasure to help. My best.
