Activity › Forums › Apple Final Cut Pro Legacy › in FCP6 when opening viewer clip from timeline viewer is white until play is hit then clip appears and plays
  • in FCP6 when opening viewer clip from timeline viewer is white until play is hit then clip appears and plays
    Posted by Randall Johannes on March 9, 2018 at 4:21 pm
    This hasn’t happened to me before. When I opened Final Cut and my final project appeared in the time line all looked normal until I double clicked a clip in the timeline to open it in the viewer but it didn’t open. The viewer was white. It wasn’t until I hit play and the playhead moved did the video appear but when I stopped the playhead the viewer became white again. When I click on the the viewer screen then a tiny box of the clip appears as long as I hold the left click button down. When I release the click button the tiny clip dissappears. Does any one know what I can do to solve this problem?
    Andy Field replied 8 years, 6 months ago 4 Members · 5 Replies
  • Shane Ross
    March 9, 2018 at 4:42 pm
    #15 White or Black Canvas or Viewer
    Shane’s Stock Answer #15: White or Black Canvas or Viewer
    Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
    OR…
    Click on the drop down menu above the Viewer or Canvas and make sure that you are on IMAGE or IMAGE + WIREFRAME.
    Shane
    Little Frog Post
  • Randall Johannes
    March 9, 2018 at 4:47 pm
    Thanks Shane, changing alpa to RGB was the problem. I’m not sure how this was changed to alpha.
    Have a great day and thanks for the quick response.
    Thanks again, Randy
  • Shane Ross
    March 9, 2018 at 7:54 pm
    My Stock Answers are still relevant! Good thing too, I knew I had one, but forgot what the solutions might be…
    Cheers!
    Shane
    Little Frog Post
  • Nick Meyers
    March 10, 2018 at 7:47 am
    [Randall Johannes] ” I’m not sure how this was changed to alpha.”
    you had the viewer selected, and you hit Shift W.
    just one of those things…
    nick
  • Andy Field
    March 12, 2018 at 5:30 pm
    FCP 6???? Are you a time traveler from the distant past?
    Andy Field
    FieldVision Productions
    N. Bethesda, Maryland 20852
