Activity Forums Adobe After Effects Expressions In extendscript,is the RenderQueueItem logType attribute still supposed to work?
  • In extendscript,is the RenderQueueItem logType attribute still supposed to work?
    Posted by Sébastien Lavoie on January 11, 2016 at 2:11 pm
    According to the After Effects CS6 scripting guide, you can change a render queue item log type by using the logType attribute.
    A LogType enumerated value; (read/write). One of:
    LogType.ERRORS_ONLY
    LogType.ERRORS_AND_SETTINGS
    LogType.ERRORS_AND_PER_FRAME_INFO
    So, by using such code:
    app.project.renderQueue.items.add(compositionToRender).logType = LogType.ERRORS_AND_PER_FRAME_INFO
    The log type should be changed. But when I am trying in both CC 2014 and CC 2015 it doesn’t work. I am able to log LogType.ERRORS_AND_PER_FRAME_INFO which exists, but it seems like it cannot be affected to the logType property. Am I doing this wrong?
    Sébastien Lavoie replied 10 years, 7 months ago 2 Members · 4 Replies
  • Xavier Gomez
    January 11, 2016 at 3:52 pm
    For me it works (CC2014), but the UI is not updated instantly.
    If the logType is initially ERRORS_ONLY, say, then doing the following returns the result: true, and the UI is updated only when hovering the mouse over the Log dropdownlist.
    app.project.renderQueue.item(1).logType = LogType.ERRORS_AND_PER_FRAME_INFO;
    app.project.renderQueue.item(1).logType === LogType.ERRORS_AND_PER_FRAME_INFO;
    What behaviour are you observing to say that it doesnt work ?
    Xavier.
  • Sébastien Lavoie
    January 11, 2016 at 3:59 pm
    When logging app.project.renderQueue.item(1).logType === LogType.ERRORS_AND_PER_FRAME_INFO; I do get true and would get false prior to affecting the value to the property, but the ui does not change. I have tried hovering over the dropdown but it does not get updated. I suppose this is a bug?
  • Xavier Gomez
    January 11, 2016 at 4:13 pm
    Well yes, if the UI never updates whatever you do, i suppose it is a bug. And when you actually render the comp, do you get the logType you asked for?
  • Sébastien Lavoie
    January 11, 2016 at 4:17 pm
    No, unfortunately it doesn’t.
