Activity Forums Adobe After Effects in CS6 – How to line up 2 different frames from same shot, and 2 slightly different angles?
  • in CS6 – How to line up 2 different frames from same shot, and 2 slightly different angles?
    Posted by Aza Allen on January 29, 2015 at 11:26 am
    I have 2 frames from the same shot, but at 2 different times. One shot has a masked out “hole” in it where an actress stood. I am using the other frame to “fill in” the hole, but the angle is slightly different as the camera was handheld but pointed in one direction (so it’s just slightly off, but noticeable)
    I used a 3D camera tracker on the layer with a hole in it, and now I’m fiddling with the 2nd layer (the X, Y, & Z rotation values) to try to line up the perspective… am I going about this the right way? Is there an easier way?
    Thanks all!
    Aza
    My portfolio can be seen at http://www.ruesterprod.com
    My personal website is http://www.azaallen.com
    Aza Allen replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
