Activity Forums AJA Video Systems In case you missedit the first time.
  • In case you missedit the first time.
    Posted by Bill on November 20, 2006 at 2:26 pm
    We have 2 FCP suites running the same setup FCP 5.1.2 with Kona LSe cards w/KCP 3.2. One box is continuously resetting the reference from Ref In to Freerun. Both suites are fed from the same generator in our rack. Our third system is a MacPro running FCP 5.1.2 with a Kona 3 w/KCP 3.1. This also receives sync from the same generator(Tektronix SPG 422). The MacPro doesnt have any issues at all. Before I go switching cables around does the KCP jump back if refernce is lost? I was leading to believe there might be a bad cable or connection sending refernce to the troubled suite. Therfore if refernce is lost KCP will fall back to freerun.
    Any thoughts?
    Bob Zelin replied 19 years, 10 months ago 2 Members · 1 Reply
  • Bob Zelin
    November 20, 2006 at 7:34 pm
    call AJA support.
    Bob Zelin
