Activity Forums Panasonic Cameras in-camera downconvert
  • in-camera downconvert
    Posted by Gerret Warner on May 16, 2008 at 4:13 pm
    Can anyone tell me how to transfer from 720/24pn to DV tape within the camera. The HVX-200 book gives all the options but I can’t for the life of me figure out how to do it.
    Noah Kadner replied 18 years, 3 months ago 3 Members · 5 Replies
  • Richard Harrington
    May 17, 2008 at 1:44 am
    24N won’t work with tape
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Gerret Warner
    May 17, 2008 at 1:47 am
    If you read the HVX-200 book it clearly states that you can downconvert 720PN to DV tape.
    May 17, 2008 at 1:55 am
    It won’t STAY 24PN
  • Gerret Warner
    May 17, 2008 at 2:23 am
    That’s why I called this thread “downconvert.” I’m simply trying to convert 720 to DV tape in camera, just as the book says. But I can’t see how. Can anyone help?
  • Noah Kadner
    May 18, 2008 at 11:12 pm
    It’s in the manual, page 87:
    You can dub any clips from a P2 card to a tape that
    you have inserted into the unit.
    The recording formats of clips that can be dubbed
    are all of the 1080i and 720P formats. In all cases,
    the data is recorded in the DV format.
    • Check to see if the tape is in a write-protected
    state. (During the dubbing operation, an error
    message does not appear.)
    • Insert the P2 card and tape into the unit, and set
    the MEDIA switch to the TAPE position. (Pages
    25 and 29)
    • When recording for the purpose of dubbing, it is
    recommended that a slightly higher setting (+5 or
    so) be used for the DETAIL LEVEL item on the
    SCENE FILE screen of the setting menu.
    3)
    Use the MENU button to close the menu,
    and press the THUMBNAIL button to return
    to the thumbnail display.
    Clips with formats that permit dubbing are
    indicated by black numbers; all other clips
    are indicated by the red numbers. (Clips
    indicated by the red numbers cannot be
    dubbed.)
    • To perform the pulldown setting when
    dubbing 720/24PA format clips
    1)
    Press the THUMBNAIL button to close
    the thumbnail display, and use the MENU
    button to open the menu.
    2)
    Select DUBBING SETUP and then
    PULLDOWN SEL. Select 24P or 24PA.
    etc….
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
