[Jonny Cates] “When you have a finished project and are ready to send it to compressor, can you just use the “I” key and the “O” key to set the range of the project, same as an in and out point? Or do you have to use the range selection tool?”
Yes, you can use the “I” and “O” key to set the range (no need to use the range selection tool) and it will send the entire project to Compressor with the In and Out point set the same way in Compressor. This allows you to actually re-adjust the in and out point after you have sent the project to Compressor.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
