Activity Forums Apple Final Cut Pro IN and OUT points in the event library?
  • IN and OUT points in the event library?
    Posted by Sean Lennon on December 3, 2013 at 5:19 pm
    Hi, folks.
    How do I find the IN and OUT points of a selection of a clip in the event library, I want to know the time of the clip from in to out so I can select another in and out point directly after the first one, is this possible?
    Also how do I enlarge the clips to select the selection i have made using the grabber tool, if the selection is a very small selection such as a frame or 2 the Grabber does not appear, is this just a flaw with the software (I’m aware that I can just add to timeline anyhow) ?
    Sean Lennon replied 12 years, 9 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    December 3, 2013 at 5:38 pm
    [Sean Lennon] “How do I find the IN and OUT points of a selection of a clip in the event library, “
    Hit control-y. This bring up the skimmer info window. You will see tc displayed.
    Also, TC is displayed in the middle HUD when in the Event Browser. Clip TC is also displayed when skimming in the timeline with clip skimming on.
    Jeremy
  • Sean Lennon
    December 3, 2013 at 5:44 pm
    Thank you!
