Activity › Forums › Adobe Premiere Pro › In and Out points in Source Audio clip effect clips on timeline?
  • In and Out points in Source Audio clip effect clips on timeline?
    Posted by Matt Chapman on September 19, 2017 at 7:58 pm
    I am doing an edit where I want to use multiple sections of the same (longer) audio clip that was recorded in a booth.
    When I set an IN and OUT point in the SOURCE window, I then use the DRAG AUDIO ONLY feature to move the selected take to the timeline.
    However, when I go to set another point on the source window so that I can use a different take at a different point on the timeline, is changes the IN and OUT point on the clip that I have already moved into the sequence. Why is this? I have not seen this behavior before from Premiere, but it is not my editing rig (I’m working at a different studio).
    The audio clip comes out with a BLUE label color on the timeline, if it makes a difference.
    Does anyone know a setting like this?
    Chapman
    Todd Perchert replied 9 years ago 2 Members · 1 Reply
  • Todd Perchert
    September 20, 2017 at 3:26 pm
    Are you opening the clip by double-clicking it on the timeline? Or from the bin? That will happen if you do it from the timeline, because you would essentially be changing the current in/out on the clip on the timeline. Make sense?
    If you’re opening from the bin, then I’m not sure what’s happening. Never had it happen that way.
    TC
