Activity Forums Adobe Premiere Pro in and out points in source and playback
  • in and out points in source and playback
    Posted by Jack Bonnett on December 15, 2015 at 2:44 pm
    Hi all,
    Just wondering if there is a way to set Premiere up so that when I’m looking at a clip in the viewer I can mark an in and an out point for a section I like but then continue to play the clip outside of those in and out points.
    At present if I put an in and an out point in a clip whenever I hit spacebar the playhead jumps to the in point and plays from there. I just want to be able to double check a couple of other bits of the clip without loosing the in and out points and having to resort to markers/subclips etc etc
    Bob Pierce replied 10 years, 6 months ago 5 Members · 4 Replies
  • Jon Doughtie
    December 15, 2015 at 4:33 pm
    That is normal behavior in the preview window. But you should be able to use your JKL keys to maneuver to areas before and after your edit points.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2014 (as of 7/2015)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Matt Galuszewski
    December 15, 2015 at 11:52 pm
    This is not the behaviour on my Mac with CC2015.1
    If I mark an in and an out I can press the spacebar and it continues from where the playhead is. It does not jump back to the in point and begin playing.
    In the bottom right of the viewer there is a WRENCH icon. Ceck that the LOOP playback isn’t ticked in the drop down menu.
  • John Haptas
    February 10, 2016 at 11:04 pm
    I take it that it is not possible to both have loop enabled (useful in trim mode) AND be able to have the spacebar toggle playback from the position indicator rather than play in-to-out? i.e. to be able to play from the position indicator by hitting the spacebar when I have in and out points I have to deselect the loop function, and then re-enable it if I want to loop in trim mode?
  • Bob Pierce
    February 11, 2016 at 1:07 pm
    In your keyboard layout you can assign a key to “play in to out”. I have mine set to f6 (a vestige of the Media 100 days). Use it all the time.
    Bob
    _____________
    Robert Pierce
    Director of Photography • Editor
    http://www.robertpiercemedia.com
