Activity Forums Adobe After Effects In After Effect rendering – do I need to stretch HD footage?
  • In After Effect rendering – do I need to stretch HD footage?
    Posted by Mandyyjobs on August 6, 2006 at 5:53 pm
    When I was looking at the rendering settings for AE, I noticed that I could stretch footage (radio button). If the footage is already HD, do I need to do this?
    Steve Roberts replied 20 years, 1 month ago 4 Members · 8 Replies
  • 8 Replies
  • Steve Roberts
    August 6, 2006 at 7:28 pm
    Stretching makes the rendered movie larger than the composition that is being rendered.
    If your composition is HD, and you want your rendered movie to be exactly the same size as your composition, you do not need to use the stretch function.
  • David Del
    August 6, 2006 at 7:35 pm
    Ok, using 6.5 – can I render HD? (I hope I don’t have to upgrade to 7.0 right now). I can’t really find the settings for it under composition settings…
  • Mandyyjobs
    August 6, 2006 at 7:36 pm
    thanks Steve
  • Steve Roberts
    August 6, 2006 at 9:09 pm
    It depends on which flavour of HD you want. 1080i or 720p? HDV? DVCPROHD? Where is your render going?
    If you can’t answer those questions, I have to ask why you want to render in HD.
  • David Del
    August 6, 2006 at 11:34 pm
    It is from a FX1 – the render is going to DVD but being shown on an HD projector. In AE, I can’t remember seeing setting for anything but DVCpro or something – I am not sure if that will work with the FX1…
    Thanks for the quick response
  • Majorasshole
    August 7, 2006 at 12:33 am
    DVD is SD and not HD. Unless you have a Blu-Ray or HDVD burner and media then your DVD signal will be SD. Currently broadcasters are the only ones delivering HD content to your TV through cable or dish. Maybe you mean 16:9 WIDESCREEN SD as opposed to 4:3 SD?
  • David Del
    August 7, 2006 at 1:25 am
    Yes, you are right. I guess is has to be SD. So what do I set the composition settings to?
  • Steve Roberts
    August 7, 2006 at 3:17 am
    Use the DV-NTSC preset for North America/Japan or DV-PAL preset for Europe.
