Activity › Forums › Adobe Audition › In Adobe Audition, why can’t I adjust the volume line on the track anymore?
  • In Adobe Audition, why can’t I adjust the volume line on the track anymore?
    Posted by David Wolf on August 7, 2013 at 2:47 am
    I don’t see a lock anywhere on the program that I can use to unlock it… this is weird, it’s never happened to me before. This is what it looks like right now. I go over the line used to adjust volume levels, and it wont show up or act as editable.
    Example
    https://www.youtube.com/watch?v=IQYCDjJmgNg
    Annie Einna replied 6 years, 6 months ago 4 Members · 5 Replies
  • David Wolf
    August 16, 2013 at 1:47 am
    Nobody?
  • Jim Leo
    October 30, 2013 at 5:27 am
    I am having the exact same problem. I have been trying everything but the volume levels just won’t budge. I know that’s not much of a help to you but at least you know your not the only person this is happening to.
    If I get a solution I will post.
  • Jim Leo
    December 22, 2013 at 8:06 am
    I was having the exact same problem. Here’s the solution: Hold down the shift key when you open up Audition. That will reset things and you should be able to adjust the volume again. It worked for me,
  • Luke Mcmanus
    September 17, 2014 at 11:00 am
    This works! Thanks a million…
  • Annie Einna
    March 24, 2020 at 10:15 pm
    Worked for me too! thank you 🙂
