Activity › Forums › Apple Final Cut Pro Legacy › imx vtr 8 track audio insert edit
Posted by Kdipin on November 17, 2005 at 8:33 amHi ,
I am trying to insert edit an 8 track audio into an sony msw-m2100p imax vtr , it only dumps 4 tracks , if I do a crsh record , it does all the 8 tracks .any suggestions
regards
Andy Mees replied 20 years, 6 months ago 3 Members · 5 Replies -
Mark Raudonis
November 17, 2005 at 3:14 pmPardon the obvious, but do you have ALL eight trks enabled? If you’re using the “edit to tape” function, you have to turn on all the tracks that you want to record to.
Also, what are you using to control the deck? An AJA box? Black magic card? Make sure that your card is set up to control eight channels.
Mark
Kdipin
November 18, 2005 at 12:24 pmHi ,
All the eight tracks are enabled , I am using a Blackmagic decklink extreme card and using the rs 422 cable to controll the deckregards
Andy Mees
November 18, 2005 at 1:37 pmdo you have the Audio/Video Settings… > Device Control Presets > Audio Mapping set to 8 channels ?
also you might want to check that your Sequence Settings > Audio Outputs are set for 8 track output and that your audio assignments are correct.apologies if you’ve already double checked all this stuff
cheers
Andy -
Kdipin
November 19, 2005 at 7:14 amHi ,
I have checked this , I am able to capture 8 tracks audio and if i do an assemble and edit , it puts the 8 channel audio back , only when I am doing an isert edit I am getting this problemregards
Andy Mees
February 24, 2006 at 12:58 pmHi Kdipin
Did you ever resolve this problem? I just found myself in the exact same position …
I’ve been trying to do an 8 channel output, also to a Sony IMX vtr, and can’t get it to work.
If I choose 8 channel audio mapping in the Device Control preset, with RS222 control, then in my ETT window the destination track control popup for the audio tracks shows channel 4 as pre-enabled … and its also greyed out and can’t be modified.
Furthermore, regardless of ouput channel selection, FCP’s device control seems unable to control channels 5 to 8 on the recorder.
In FCP, if I select any output channels above channel 4, then all channel selections below 4 are ignored, and the recorder seems to receive a signal to enable channels 1 to 4 relative to my selections in FCP for channels 5-8.All very strange. The actual output from the Decklink card is exactly as it should be with the output assignments correctly mapped to the output channels. The only immediate workaround I can find is to put the record deck next to the FCP and manualy override/enable the tracks to insert directly on the deck … it works but is far from ideal.
Any tips greatly appreciated. If anyone else would care to experiment, just create a device control preset with Audio mapping set to 8 channels and see if your ETT window will allow you to enable/disable channel 4.
Cheers
Andy
