Activity › Forums › Broadcasting › IMX format, please help!
  • IMX format, please help!
    Posted by Paul Dombrovskis on August 22, 2009 at 7:52 am
    Hi guys,
    am new to IMX format and to your site aswell. I will have to work with IMX and i need to know how big would be a 10 second file recorded in IMX30+ 8 audio.
    thnaks in advance
    cheers
    Paul
    Asmund Voll tesdal replied 17 years, 1 month ago 3 Members · 4 Replies
  • Bob Zelin
    August 23, 2009 at 2:31 pm
    MPEG IMX is a 2001 development of the Digital Betacam format. It uses the MPEG compression system, but at a higher bitrate than Betacam SX. The IMX format allows for a CCIR 601 compliant video signal, with eight channels of audio and timecode track. It lacks an analog audio (cue) track as the Digital Betacam, but will read it as channel 7 if used for playback.
    Compression is applied in three different formats: 30 (6:1 compression), 40 (4:1 compression) or 50 Mbit/s (3.3:1 compression) which allows different quality/storage efficiency ratios. Video is recorded as MPEG-2 I frames only.
  • Paul Dombrovskis
    August 23, 2009 at 2:38 pm
    thank you for that!
    what would be the size of 10 sec IMX-30 8 audio format clip??
    cheers!
  • Bob Zelin
    August 23, 2009 at 9:46 pm
    I have no idea.
    Bob Zelin
  • Asmund Voll tesdal
    August 26, 2009 at 7:19 pm
    Well, IMX30 has a bitrate of 30 mb/s (megabits), so a 10 sec clip should be 37.5 mB (megabytes) of video. Don’t remember the audio format for IMX, but I’ll guess 16 bit 48k, which in 8 channels for 10 secs should be 7.68 mB. Then add some metadata on top of that, and you should have an approximate size.
