Activity Forums Adobe After Effects improving RAM previews
  • improving RAM previews
    Posted by Paul Nevison on January 9, 2008 at 1:12 am
    My Ram previews seem to have gone a little south.
    I can only get a few seconds worth of preview at either full or half rez….it improves in third and quarter rez but still not stellar!
    i dont think it’s a particularly complicated comp, it’s a camera tracking along a canned animation with DOF and motion blur.
    Is there something i can do to improve the previews?
    thanks
    Macpro Duel core 3Ghz
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    BMD Decklink HD Extreme 6.6
    PAL Land
    Peter Van der zee replied 18 years, 7 months ago 3 Members · 6 Replies
  • Darby Edelen
    January 9, 2008 at 4:23 am
    [paul nevison] “Is there something i can do to improve the previews?”
    You can also set the RAM preview to skip frames, which doesn’t really ‘improve’ the preview but it does extend the amount you can preview.
    I usually RAM preview at half rez and skip every other frame to get the timing right and then spot check it by scrubbing at full rez (or full rez RAM preview for important/involved spots) to make sure there are no anomalies.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Paul Nevison
    January 9, 2008 at 4:32 am
    thanks Darby,
    I’m pretty new at AE so any tips are appreciated. Does having more RAM help with this i wonder? How much RAM can AE CS3 actually access?
    4.0G RAM
    OS 10.4.11
    QT 7.3.1
    FCP 6.0.2
    AE CS3 8.0.1.8
    PAL Land
  • Darby Edelen
    January 9, 2008 at 6:51 am
    [paul nevison] “How much RAM can AE CS3 actually access?”
    AE CS3 can access 3GB of RAM per instance on a Mac. However, the amount available for your RAM previews will be determined by the Cache size in your Memory & Cache settings. I haven’t tested RAM previews with multiprocessing enabled, but I would hope that if you had it enabled with 3 instances of AE you would have a limit of 9GB of total RAM (3GB per processor) for renders/previews.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Peter Van der zee
    January 9, 2008 at 10:42 am
    With after 7 on intel, memory issues were a dissaster, CS3 is a lot better but I find a lot of times
    RAM “fills up”. Do you Purge the memory? (since you’ve said to be new) edit-purge-all, normaly does the trick. Another thing is the size of the comp; a big comp cost after a lot to preview, you can pre-comp in a smaller one, size down and enjoy full-length previews.
    vanderzee.tv
  • Paul Nevison
    January 9, 2008 at 11:53 am
    thanks a lot folks….didn’t know about purging the cache but that seems to have helped performance a lot.
    nice tip on the resizing of a precomp!
    thanks
    4.0G RAM
    OS 10.4.11
    QT 7.3.1
    FCP 6.0.2
    AE CS3 8.0.1.8
    PAL Land
  • Peter Van der zee
    January 10, 2008 at 10:50 am
    Not entirely, Dave, I’ve noticed with extreme comp-sizes, even in quarter and 25% screensize, a preview stops halfway. Precomping in a quartesize comp, previews the whole length.
    Don’t ask me why…
    vanderzee.tv
