Activity Forums VEGAS Pro Improve Flesh Tones
  • Improve Flesh Tones
    Posted by Mark Prebonich on May 22, 2011 at 8:15 pm
    In a video of my daughter’s dance recital, the flesh tones are very bright (too white) and washed out. I would like to make this more realistic, warm, and not so harsh. How am I able do this for just the bright skin tones? Thanks.
    -Mark
    Mark Prebonich replied 15 years, 4 months ago 2 Members · 4 Replies
  • Mike Kujbida
    May 22, 2011 at 8:30 pm
    Mark, I’m not sure if this tip (grabbed it from another forum some time ago) will work with your version of Vegas but it’s worth a try.
    Put 3 filters, a “Invert” (at 100%), “Color Corrector”, “Invert” (at 100%).
    Then lift up the gamma of the color corrector in the middle.
    This darkens highlights first, in the logarithmic fashion, more like a “iris closing” way.
    You can also put a color corrector secondary to select reds and lower the gamma a bit.
    Dark or bright may also have to add or remove a bit of saturation on the color corrector filter.
  • Mark Prebonich
    May 22, 2011 at 8:35 pm
    Here is a 10 second clip showing the finding. When I play the video in WMP at full screen, it looks quite a bit more pronounced with much less skin tones apparent.
  • Mark Prebonich
    May 22, 2011 at 8:40 pm
    Wow, that response was very fast. I have Vegas Pro 10d. I’ll give it a whirl and get back with the results. Thank you for the input.
    -Mark
  • Mark Prebonich
    May 22, 2011 at 10:26 pm
    The secondary color corrector worked best. I was able to adjust the washed out bright skin colors to a more realistic flesh tone. Now, what is proper FX in order to make the bright colors darker without darkening the entire video? Things are definitely looking much better. I appreciate the assistance. Thanks.
    -Mark
