Activity Forums Adobe Premiere Pro Impression of looking through binoculars
  • Impression of looking through binoculars
    Posted by Zvi Twersky on April 4, 2007 at 6:05 pm
    I’ts not hard to create a mask to give an impression of looking through binoculars, but I wanted to know if there was a preset already in Premiere Pro that gives this effect to a clip.
    Also, does anyone know how to give the effect of looking at a viewfinder. You can see this many times on movies, where there are 4 ‘L’ shaped brackets on the 4 corners of the screen and a blinking red light, maybe with a blinking red word that says “recording” or “live”. Again, probably not hard to create, but is there a build in preset for this king of effect?
    Tomasz Jelinski replied 15 years, 3 months ago 6 Members · 12 Replies
  • 12 Replies
  • Mike Velte
    April 4, 2007 at 6:48 pm
    Sorry, no presets or templates to help just a couple of suggestions;
    1. Both your ideas can be created in the titler or Photoshop.
    2. The flashing red light is going to be a separate title with opacity keyframes…make about 10 on/off cycles and then just overlay additional copies (copy/paste) for the length needed.
    3. Add the Timecode effect to a transparent video clip and overlay that over your LCD title for more realism.
    4. Dont forget to export your titles and save them for future use.
  • Steven L. gotz
    April 4, 2007 at 7:25 pm
    There is a plugin for those effects. Camera POV – https://www.profoundeffects.com/products/camerapov/
  • Zvi Twersky
    April 4, 2007 at 7:32 pm
    Thanks guys!
    What about the binoculars effect? Just paint it in titler?
  • Zvi Twersky
    April 4, 2007 at 7:34 pm
    The CameraPOV plugin is for After effects, not premiere pro. This would make me have to do importing, rendering, exporting and importing again into Premiere Pro. Is there a similar plugin for premiere pro?
  • Vince Becquiot
    April 4, 2007 at 7:44 pm
    I actually made a simple one a while back. You can do a “save as” on the Gif below (720×480) and import it in Premiere, then apply the “Blue Screen Key” effect to it. It’s no award winning design but you get the idea 😉
    Here are the original Photoshop files if you want to tweak the settings.
    https://www.kaptis.com/media/web/Viewfinder_with_record.psd
    https://www.kaptis.com/media/web/Viewfinder_NO_record.psd
    Cheers,
    Vince
  • Zvi Twersky
    April 4, 2007 at 7:47 pm
    Vincent, thanks so much for sharing your work!
  • Vince Becquiot
    April 4, 2007 at 7:51 pm
    For binoculars, you can use the circle effect, increase radius, add feather, change blending mode to stencil Alpha.
    Also see second post in this thread for viewfinder overlay.
    Cheers,
    Vince
  • Steven L. gotz
    April 4, 2007 at 8:09 pm
    I beta tested it in Premiere Pro so I know it works.
  • Vince Becquiot
    April 4, 2007 at 8:23 pm
    I actually forgot to include the interlace file, to add a bit of a more realistic look, that should be inserted between the viewfinder and the video.
    https://www.kaptis.com/media/web/Interlacing.psd
    Vince
  • Zvi Twersky
    April 4, 2007 at 8:56 pm
    Hey Steven, I also tried to install it, and it works in Premiere Pro too! Thanks!
