Impossible to mount volume on ATTO 644
I’ve been looking around for solution for days now but nothing would work,
I have a ATTO 644 in a macpro running 4x 3TB drive in RAID 5.
Hardware wise, it seems working fine, but recently, some people at the office have been copying hudge amount of data both upload and download with the same account over several computers.Now the volume is visible in disk utility, but impossible to mount,
Hardware wise, atto test tells me the array has no problem at all and i’ve tried Techtool pro to get the volume back online.
It worked well, then a few minutes later, the volume became read only, i’ve run again techtool pro, and since then, impossible to mount the volume and or transfer anything.Any suggestion on what i should be doing ?
I’ve tried disk warrior without success, can’t even see the volume, and now Techtool pro just tells me that there is a problem whenever i try to get the volume structure repaired.The volume is an HFS+
It’s been running fine for more than a year, i can’t figure out what is going on…. or what i should do.
We have backed up most of the files, but still we have some data that are not yet transfered and now we can’t figure how to access those…Any suggestion or help is more than welcome.
ALex
