Activity › Forums › Apple Final Cut Pro Legacy › Impossible to batch capture
  • Impossible to batch capture
    Posted by Cyrilv on January 10, 2007 at 7:21 pm
    Hello,
    I’ve a log list, and I need to batch capture it but I have a message saying that there is not enough preroll etc, or a TC problem.
    I’m working with DV PAL with the 5.1.2 version.
    It is not the first time I can’t batch capture. But the tape is fine and it looks like there is a bug. Also the audio behave weird in the new version.
    Does anyone experiment the same problem?
    Arnljot Bringedal replied 19 years, 8 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    January 10, 2007 at 8:20 pm
    Is there enough preroll? have you checked the tape to see?
    DV decks usually require at least 3 seconds of pre roll of continual and accurate timecode.
    Was the material shot with a Canon camera?
    Audio behaves the same here as it always has, what’s different?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Peter Dewit
    January 10, 2007 at 10:06 pm
    Have you checked if the TC at the start of the tape is consistent. It might just be a TC break. You can try to enable capture across TC breaks in the User preferences if you’re not sure.
  • Arnljot Bringedal
    January 12, 2007 at 11:12 pm
    Is there an issue with canon and preroll?
    and the 3 sec preroll -what does that mean? just shoot 3 secs of nothing important?
    *** Norwegian videojournalist & Editor***
