Activity › Forums › Adobe Premiere Pro › Importing Xvid/Divx file, editting, then exporting with no quality loss
  • Importing Xvid/Divx file, editting, then exporting with no quality loss
    Posted by Aden Williams on January 22, 2009 at 8:36 am
    I’ve got some Divx/Xvid compressed video files that I want to trim down. I import them fine, and get the trimming done quite fast, but the exporting has become problematic for me.
    If I export with the default options for an *.avi, quality loss happens and the size of the file change (adding a large black border when playing in fullscreen).
    Is there any way to just export/save them, allowing them to look exactly like they had, only trimmed up? Ideally without saving them uncompressed and having to recompress them with another program.
    It seems like such a simple task, but man does my mind hurt. :-\
    Thanks in advance.
    Aden Williams replied 17 years, 8 months ago 3 Members · 5 Replies
  • Eddie Lotter
    January 22, 2009 at 2:38 pm
    [Aden Williams] “Is there any way to just export/save them, allowing them to look exactly like they had, only trimmed up?”
    Not in PPro, no.
    You will need to find another tool to cut without re-encoding.
    Cheers
    Eddie
  • Aden Williams
    January 22, 2009 at 6:57 pm
    Any ideas on what program(s) would be sufficient for that? Like I said, I’m not looking to do extensive edits/effects, just simple cuts.
  • Eddie Lotter
    January 22, 2009 at 7:17 pm
    I’m afarid I don’t know because I never use highly compressed footage as source material.
    Hopefully someone else will have some recommendations. It would also be worth doing some research on the Internet.
    Cheers
    Eddie
  • Namn Namnsson
    January 28, 2009 at 2:20 pm
    Aden,
    Download the freeware program called VirtualDUB. It has a video (and audio) setting that’s called “Direct stream copy”. This is the tool you want to use – simply set the option, then set in/out points and finally save the video. The video data itself will be entirely untouched.
    Regards,
    Rikard
  • Aden Williams
    January 30, 2009 at 3:00 am
    Worked fantastically. There were a lot of programs that claimed they’d do it without quality loss, but this was the only one that I managed to find that actually didn’t touch the video quality at all.
    Thanks.
