Activity Forums Adobe Premiere Pro Importing XML results in double files
  • Importing XML results in double files
    Posted by Dustin Straube on February 11, 2020 at 9:52 pm
    I’m working in animation building animatics and we’re working with Premiere importing XMLs from Storyboard Pro. Everything works fine, except when I import the XMLs it will double the brand new jpegs I’ve imported. So there is one set being used in the timeline of the imported XML and then there is a duplicate set not being used anywhere in the project. The duplicate set always has the addition to the name of “.jpg” while the clips being used don’t have this file extension. Both point to the exact same file on our server. Has anyone had any issue related to this? Is there a way to stop it from doing this?
    Dustin Emerson Straube
    dustin.straube@gmail.com
    Oliver Peters replied 6 years, 6 months ago 3 Members · 3 Replies
  • Shane Ross
    February 12, 2020 at 4:25 am
    Which version of PPro are you running? Because this was a BIG issue with 2018 and earlier…supposedly fixed in later versions. But yeah, huge pain
    Shane
    Little Frog Post
  • Dustin Straube
    February 12, 2020 at 6:02 am
    I am in fact using 2018 (I’m waiting for a new computer on my current job). However, there is another editor on the show, and he is using 2020 and experiencing the same problem still.
  • Oliver Peters
    February 12, 2020 at 1:24 pm
    Try highlighting the bin and use the “consolidate duplicates” command. That may work for you.
    – Oliver
    Oliver Peters – oliverpeters.com
