Importing XML into Resolve- clips & audio dropped
Hi all
Beginner to DaVinci so please bare with me.I cut a project together on FCP X, text, transitions, clips, sound- everything perfect and ready for colour.
I then took all project files and the exported XML on a hard drive, went to a MacPro, copied all files across and proceeded to import the XML into DaVinci with a view to do a round trip after grading back into FCP.
When in DaVinci my text animations didn’t operate as had done in FCP, some clips were replaced with a black screen and my audio was not there. Da vinci looked for all clips and found all but 2 (the 2 files were in the same folder, it should have found them). However 98% of my clips were there so I proceeded to spend the evening grading the clips…
I then exported the XML after rendering (picking the round trip option)
now I’m back on FCP, imported the XML …
… some audio missing, text animation no longer there (but the key frames are??), transitions not there however the colour has been graded.
Any advice you guys can give me to fix this would be very much appreciated. Really don’t want to have to re edit my project. Did I get soemthing wrong with the XML import in Davinci?
many thanks
