Activity › Forums › Apple Final Cut Pro Legacy › Importing xml into FCP 7.0.3 gets “critical error”
Posted by Mads Astrup on September 14, 2011 at 10:11 pmHi,
I am trying to import a sequence xml files with subtitles into my FCP 7.0.3.
I got the file from a professional translation company. First of two files worked fine. The second was aborted due to “critical error”.
Do anybody has a way too solve the problem?
Thx, MADS
Anders Teigen replied 14 years, 11 months ago 3 Members · 6 Replies -
Shane Ross
September 14, 2011 at 10:51 pmHave them redo the third one and send again. Might have been an issue in the creation of that particular XML.
Shane
Read my blog, Little Frog in High Def -
Mads Astrup
September 15, 2011 at 6:19 amHi Shane,
I already did that, and it still does not work. Other suggestions?
Shane Ross
September 15, 2011 at 4:26 pmSend as a different XML version? Instead of V5, how about v4? v3?
Shane
Anders Teigen
September 15, 2011 at 6:44 pmHi!
If you work in a Norwegian setting, some applications can create problems in the XML if there are character encoding mismatch. Characters like Æ, Ø and Å can be misinterperated if encoded otherwise, and create faulty XMLs. The character encoding should be UTF-8 through the whole workflow. Start by checking the first lines in the xml (read in a text editor) and look for “encoding”. Then check if there are language preferences in the subtitle generator.
There can also be isues with other special characters sneeking in to the subtitles.
regards
-anders -
Mads Astrup
September 16, 2011 at 8:28 amHi Shane and Anders,
The company ended up sending six different files, and in the end it worked. Don’t know why.
@ Anders – the text was in english.
Thx for taking your time.
Regards Mads
