Activity Forums Apple Final Cut Pro Importing XML from Davinci Resolve
  • Importing XML from Davinci Resolve
    Posted by Jordan Mena on April 10, 2013 at 11:18 pm
    I did a grade for a half hour show in Resolve. When finished I did a FCP XML roudtrip for delivery. I decided to bring in my XML into FCPX to check before handing off to the client. I understand that FCPX doesn’t take regular XML as it has it’s own XML code. I ran my Resolve XML threw 7 to X generating an XML FCPX can see. It successfully created a new Event and a new Compound clip. I can see the clips in the event browser but when I open up the xml timeline I see the clips but most frames are black and when I try to skim through the timeline I get the spinning beach ball and FCPX crashes. Anyone experience this? Workaround or fix?
    thanks in advance, J
    Jordan Mena | Editor | Colorist | Producer
    Los Angeles, CA
    jordanmena.com
    Shane Ross replied 9 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    April 11, 2013 at 12:59 am
    Resolve has FCPX XML available.
    No reason to use 7toX.
  • Charlie Austin
    April 11, 2013 at 1:02 am
    [Jordan Mena] “Anyone experience this? Workaround or fix?”
    Jeremy beat me to it… Also, probably no help, and this isn’t an RTFM post. 🙂 But… did you check the manual, it seems there are a few steps other than just exporting XML involved. Starts on page 565…
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Jordan Mena
    April 11, 2013 at 2:56 am
    I know that Davinci has an xml export for FCPX, but my client is on Legacy. I was just trying to see if it worked. I will look at the manual. Thanks!
    Los Angeles, CA
    jordanmena.com
  • Jeremy Garchow
    April 11, 2013 at 3:03 am
    [Jordan Mena] “I know that Davinci has an xml export for FCPX, but my client is on Legacy. I was just trying to see if it worked. I will look at the manual. Thanks!”
    OK. This now makes more sense.
    What format is your original material?
    What frame rate?
    If you do use the FCPXML roundtrip function, does it work?
  • Jordan Mena
    April 11, 2013 at 9:17 pm
    My material is Prores 422HQ 23.98. I used the FCPXML out of davinci, and with a little jimming I got it to open fine in FCPX. All good. Thanks!
    Los Angeles, CA
    jordanmena.com
  • Mark Linthicum
    April 16, 2017 at 9:25 pm
    Could you share how you got it to work?? i have the same issue.
    Thanks, Mark
  • Jeremy Garchow
    April 16, 2017 at 10:34 pm
    What issues are you seeing exactly and what have you tried?
  • Shane Ross
    April 17, 2017 at 5:45 pm
    Resolve also has regular XML export. It’s near the bottom of the options. I use that a lot as I need to go to FCP 7 to convert the XML to work in Sequence CLip Reporter for clip reports.
    Shane
    Little Frog Post
