Activity Forums VEGAS Pro Importing XDCAM HD from PDW-U1
  • Importing XDCAM HD from PDW-U1
    Posted by Charles Martin on May 15, 2011 at 3:19 pm
    Trying to import material into Sony Vegas Pro 10d …
    I’ve got the PDW-U1 hooked up—-Laptop is seeing it…but can’t quite figure out the process for importing to a Vegas project.
    I ‘imported’ using the ‘import’ method in the dropdown…but then the ‘containing folder’ is the Disk on the PDW-U1. Do I need to use ‘device explorer’? and if so..what is the process…? I’ve tried device explorer but get hung up as if I am not following the correct procedure.
    Thanks for any advice you can offer.
    Charles Martin replied 15 years, 3 months ago 2 Members · 2 Replies
  • Mike Kujbida
    May 15, 2011 at 4:40 pm
    I know nothing about this drive so this is a stab in the dark.
    Have you tried XDCAM Explorer?
    It’s under the View menu.
    The online help menu gets into a lot of XDCAM suggestions so check it out too.
  • Charles Martin
    May 17, 2011 at 10:53 am
    OK…thanks…will try this out and let you know.
