Activity › Forums › Avid Media Composer › importing with multiple raster red footage
  • importing with multiple raster red footage
    Posted by Len Hugh on March 6, 2010 at 12:41 pm
    I have had this situation before where some of the red footage was shot 16×9 and some of it at 2:1.
    I remember a setting which was something along the lines of “resize to fit raster on import” which was a box you could check on import but I am buggered if I can find it now when I am faced wit a similar situation.
    does anyone know where it is?
    thanks
    Len Hugh replied 16 years, 6 months ago 3 Members · 4 Replies
  • Job Ter burg
    March 6, 2010 at 3:58 pm
    Importing it into what?
    If you use MetaFuze to transcode to MXF, you can simply choose “Letterbox”. It will create 2:1 wth Ltbx inside 16×9. What was 16×9 will remain 16×9.
  • Len Hugh
    March 7, 2010 at 3:05 am
    my workflow is red rushes> qt wrappers and ALE> Avid so I am importing into Avid.
    thanks anyway I have found it.
    in older versions it is the “Maintain and Resize” check box
    in versions 3 and on its now “resize image to fit format raster” check box in the options of an import.
  • Michael Phillips
    March 7, 2010 at 2:24 pm
    Are you not scaling on export from RED RUSHES? There is a fit to width, heigth when the 1920 x 1080 is selected. It will be a faster transcode if the movie size is already 1920 x 1080.
    Also, look to the new REDCINE-X tha exports MXF/DNxHD directly.
    Michael
    Michael Phillips
  • Len Hugh
    March 8, 2010 at 10:58 am
    Thanks I will check it out.
