Activity Forums Adobe After Effects Expressions Importing weird sized photos…
  • Importing weird sized photos…
    Posted by Zack Florance on February 8, 2006 at 6:26 am
    Hello fellow AE Users,
    I want to import about 30 JPEG’s of different resolutions into a composition. Does anyone know how I can “batch import” them all to be 720 X 480 and all be 7 Seconds long without have to individually adjust them in the timeline?? Thanks a bunch in advance!
    Zack
    Amish Ed replied 20 years, 7 months ago 3 Members · 2 Replies
  • Mylenium
    February 8, 2006 at 6:30 am
    You can automatically scale automatically them using an expression. That has been discussed not so long ago, so do a search. The rest can be done using Keyframe Assistants –> Sequence Layers.
    Mylenium
    [Pour Myl
  • Amish Ed
    February 8, 2006 at 4:37 pm
    Similiar to Mylenium’s solution; here’s how I’d do it…make a 7sec. comp at 720×480. Dump all your layers into it, select them all and hit “comand option F” (this will resize all the images to 720×480). Change your comp length to at least 3min30sec (30 clips at 7sec each) and with all the layers selected go to Keyframe Assitants>Sequence Layers. There you can add overlap and fades if you need them.
    Amish Ed
    “Shoot ’em all and let the Editor sort ’em out!”
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
