Activity › Forums › VEGAS Pro › Importing WAV file larger than 4GB is causing error
  • Importing WAV file larger than 4GB is causing error
    Posted by John Romein on September 12, 2014 at 3:16 pm
    I just ingested, via Machina, two 3 hour DVCAM tapes resulting in some very large AVI and WAV files. The WAV files are each over 4GB. Now I’m pulling these files into Sony Vegas Pro 12/13 with the intent of quickly rendering them out for DVD’s. No problem wit the AVI files. The problem is that when I drop the WAV files onto the timeline I get an error and the the resulting file is only a few seconds! I realize that Machina created illegal WAV file sizes (should be 2GB or less). I looked at the files using Mediainfo and they are about 3 hours each…which is correct.
    What do I need to do to get the WAV files into Vegas?
    Norman Black replied 12 years ago 2 Members · 6 Replies
  • Norman Black
    September 12, 2014 at 3:27 pm
    There are a couple of WAV extensions for large WAV files. The Sony W64 format (Soundforge) and the RF64 format. Sony Vegas obviously supports the W64 format but I do not think it supports the RF64 format. MediaInfo should be able to identify which WAV extension format was used.
  • John Romein
    September 12, 2014 at 3:41 pm
    Thanks Norman.
    Here’s the output from Mediainfo:
    General
    Complete name : R:\RAW\tape 2.wav
    Format : Wave
    File size : 4.00 GiB
    Duration : 3h 6mn
    Overall bit rate mode : Constant
    Overall bit rate : 3 072 Kbps
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : 00001000-0000-0100-8000-00AA00389B71
    Duration : 3h 6mn
    Bit rate mode : Constant
    Bit rate : 3 072 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 32 bits
    Stream size : 4.00 GiB (100%)
    Any suggestions as to how to get the file into Vegas? Do I need to go some 3rd party converter software? I tried to fool Vegas by changing the extension to W64…didn’t work.
  • Norman Black
    September 12, 2014 at 4:57 pm
    I was hoping MediaInfo would have said something more than WAV. Hoping for W64 or RF64. Changing the extension is not likely to do anything. Applications don’t care about the file extension. They go my what the file header tells them.
    It is interesting that in the MediaInfo report the file is exactly 4GB in size. It is possible to have normal WAV format files be up to that size. Not all applications would support this. This can happen if the offsets in the file are treated as unsigned numbers, versus signed. Supposedly Vegas does support these files. There is even a preference to render up to 4GB WAV files. Unchecked by default.
    I also wonder about a boundary condition problem since the file is at the exact limit if it is a classic WAV format. If so, the boundary bug could be in Vegas or the software that generated the file.
    Whatever the file is, Vegas does not like it. You need to find some tool that does like it and convert to something Vegas does like. W64 or split the file into a few pieces.
    Maybe the eac3to utility. “eac3to Problem.WAV Fixed.W64”
  • John Romein
    September 12, 2014 at 5:51 pm
    It just happened that this file is 4GB. The other file of tape 1 is 4.17GB and the Mediainfo is the same otherwise. I downloaded Audicity and tried to load the file into it as a wav file….same error issue. I also tried to load the file as a RAW and it created a 13 hour file on the timeline! The file is very noisy, sloooow (explains 13 hours), 32bit float, mono. I changed the file to 24bit PCM….no change. The file should be a stereo…but I don’t think changing this would help.
    You mentioned eac3to. I’ll download it and see if it can resolve this issue.
  • John Romein
    September 12, 2014 at 7:19 pm
    Thanks Norman! This forum is great!
    I downloaded the program eac3to and ran it as you suggested.
    eac3to tape2.wav tape2.w64
    Took almost 4 minutes to convert. Loaded it into Vegas and it works…I have a 3 hour audio track.
    Thanks again!
  • Norman Black
    September 12, 2014 at 10:41 pm
    Glad it worked. Yes, writing 4GB+ to disk takes a while. Also, don’t worry about audio quality loss. There is no loss “converting” from PCM to PCM audio.
