Activity Forums Avid Media Composer Importing vs. AMA
  • Importing vs. AMA
    Posted by Ken Calcaterra on September 4, 2010 at 2:09 pm
    I’ve been transcoding footage for better playback on my system. Does it make more sense to import vs. bringing in AMA and then transcoding?
    I’m trying to figure out the best workflow. Thanks.
    Desktop – Intel Core 2 Quad Q6600 @ 2.40ghz
    Ram – 6gb
    Nvidia Quadro FX 580
    Window 7 64 bit
    Laptop – Intel Core 2 Duo t9300 2.50ghz
    Ram – 4gb
    Unknown Video card
    Windows 7 64bit
    Richard Sanchez replied 16 years ago 3 Members · 4 Replies
  • Michael Phillips
    September 4, 2010 at 6:17 pm
    Depending on codec, AMA allows you edit directly from the sources being referenced. AMA with transcode is near real time versus a 2x longer real time with Import. AMA also allows you to select spans of clips to transcode rather than the whole clip.
    What you don’t get with AMA is control over gamma such as RGB or 601/709 as part of the process. Also, don’t AMA BWF audio clips – it will work, but QuickTime really messes up the timecode inside the file.
    Michael
    Michael Phillips
  • Ken Calcaterra
    September 4, 2010 at 9:47 pm
    It sounds like the best work flow is to import via AMA and then immediately transcode. I noticed there are different DNxHD resolutions depending on 1080 or 720 and frame rate.
    Is it better to use the standard DNxHD or the one with the X?
    What is BWF audio?
    Thank you kindly for your time and knowledge.
    Ram – 6gb
    Window 7 64 bit
    Ram – 4gb
    Nvidia 8700M
    Windows 7 64bit
  • Michael Phillips
    September 5, 2010 at 12:05 am
    The “x” denotes a 10 bit resolution. If your sources are 10 bit then you should – but most compressed format are 8 bit and will look fine as 145/120/115 for 1080.
    BWF is a broadcast WAV file, the format recorded by audio field recorders like Sound Devices, Tascam, Deva, etc.
    Michael
    Michael Phillips
  • Richard Sanchez
    September 6, 2010 at 4:28 pm
    You also can’t modify the metadata in an AMA clip. I recently brought in large groups of DVCPRO HD on P2 cards, and need to assign auxiliary timecode to sync them. I couldn’t do it until I transcoded them.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
