Activity Forums VEGAS Pro Importing VOB Audio Issue
  • Importing VOB Audio Issue
    Posted by Marlen Mathers on February 16, 2014 at 8:31 pm
    Wondering if anyone can help on an audio issues I’m having with the importing of VOB files. It seems that no matter what method of importing VOB’s (File | Import | DVD Camcorder Disc or just dragging the the entire contents of the “Video_TS” folder on the DVD) I use, the main audio track is extremely quiet, while the background track (secondary track seems to be fine). The dialog between my actors is very low.
    The DVD plays fine as a “DVD” on the computer, it’s only when I try to import that I seem to loose the main audio track. Is there a Preference setting or a codec that is missing? Not sure if this has anything to do with a dolby setting or if a program like Womble would fix this. This is a fairly new problem as I’ve never experienced this before.
    I’m using Sony Vegas Pro 10.0e (64bit) Build 738.
    Thanks in advance.
    Marlen
    Abhi Nash replied 12 years, 7 months ago 3 Members · 5 Replies
  • Abhi Nash
    February 17, 2014 at 10:26 am
    VOB is not a natively supported codec for NLEs’.
    This will definitely help you out.
    1.Download Handbrake its a free app.
    2.Select the source file as your desired .vob file convert it to MP4.
    Then import it into Vegas and it will work.
    -Abhi
  • Marlen Mathers
    February 17, 2014 at 2:45 pm
    Thanks Abhi. I have Handbrake, but didn’t think of using it in this situation. Let me give it a try.
    Thanks again.
    Marlen
  • Steve Rhoden
    February 17, 2014 at 3:14 pm
    That’s an option you can try Marlen.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Marlen Mathers
    February 17, 2014 at 3:38 pm
    Thanks guys…that did the trick.
    Marlen
  • Abhi Nash
    February 17, 2014 at 5:20 pm
    Good to know Marlen!
    Don’t forget to post here if you need any kind of help!
    -Abhi
