Activity › Forums › Apple Final Cut Pro Legacy › Importing: visual problems
Posted by Annette Lathbridge on January 15, 2011 at 4:15 pmHello
I received footage from a film maker that was shot using an XD HD Camera. It’s a quick time file,I’ve updated my quick time software. When I imported it into final cut, I could only hear the sound but could not see the images. can anyone help me?annette lathbridge
Annette Lathbridge replied 15 years, 8 months ago 3 Members · 7 Replies -
Jeff Greenberg
January 15, 2011 at 5:57 pmCan it be opened in QuickTime? It sounds like you don’t have the codec installed. What was the specific camera?
Best,
Jeff G
Anthony Bari jr.
January 16, 2011 at 11:35 pmDo you have the RAW clips from a card? Just QT movies stripped from the original source?
Helps to download the Freeware Sony has:
https://www.sony.ca/xdcamex/support.htm
Hope that helps you.
Jeff is right, make sure you have the Codec installed on your machine.
*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
“Semper Fi USMC” -
Annette Lathbridge
January 19, 2011 at 8:12 amHi Jeff
Thanks for responding the file can be opened in quick time but I only hear the sounds and can’t see the image whenever it’s played. The camera used was a Sony XD Cam EX1Annette
Jeff Greenberg
January 19, 2011 at 2:24 pmAnnette, I know it’s a silly question: Do you have FCP installed on the system you’re looking at? If you don’t have the proapps, the XDCAM codecs aren’t on the system.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Annette Lathbridge
January 20, 2011 at 3:49 pmHi Jeff,
Iv’e got final cut express installed but not final cut pro. Would I need to install final cut pro in order to see the footage?Annette
Jeff Greenberg
January 20, 2011 at 5:37 pmYup, that’s the problem. The codec requires a license and FCE doesn’t have the license – FCP does.
You could find someone to convert it for you to FCP, you could try recording it into a camera/deck that FCE does communicate with (such as HDV).
Best,
Jeff G
