Activity Forums Adobe Premiere Pro Importing video with alpha channel issue
  • Importing video with alpha channel issue
    Posted by Sam Bowman on December 13, 2016 at 10:19 am
    I have a video that is meant as a transition. basically a hole is to open up spinning on the screen getting bigger to display the video underneath it. The problem is that the parts of the transition video that are supposed to be opaque have this weird transparency issue. It is like there is a static white noise layer of transparency over the entire clip. You can see it best in the black in the corners. I will include pictures
    it is supposed to look like this (picture taken from sony vegas which works properly for this clip) where the black is solid
    I’m really at a loss here, I am on a windows 7 machine running Adobe Premiere Pro CC 2017. Here is the metadata for the clip in question.
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2005.03 (qt )
    File size : 1.54 GiB
    Duration : 10 s 0 ms
    Overall bit rate mode : Variable
    Overall bit rate : 1 323 Mb/s
    Encoded date : UTC 2016-12-22 12:07:05
    Tagged date : UTC 2016-12-12 12:21:04
    Writing library : Apple QuickTime
    ©TIM : 00:00:00:00
    ©TSC : 25
    ©TSZ : 1
    Video
    Format : RLE
    Format/Info : Run-length encoding
    Codec ID : rle
    Bit rate mode : Variable
    Bit rate : 1 321 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 FPS
    Color space : RGBA
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 25.475
    Stream size : 1.54 GiB (100%)
    Language : English
    Tagged date : UTC 2016-12-22 12:07:05
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 1.83 MiB (0%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 00:00:00:00
    Time code, striped : Yes
    Language : English
    Any help would be greatly appreciated, I’ve been stuck on this problem for hours I cant find a solution on my own.
    Sam Bowman replied 9 years, 8 months ago 2 Members · 3 Replies
  • Andrew Drachman
    December 13, 2016 at 2:32 pm
    Have you tried going in to the effect controls on the clip and changing the opacity to screen?
  • Sam Bowman
    December 13, 2016 at 10:28 pm
    Yes, I have tried that it makes the clip even more transparent and you can see more of the video underneath it.
  • Sam Bowman
    December 13, 2016 at 10:30 pm
    This is what happens with screen opacity when there is a green matte behind it.
