Activity Forums Avid Media Composer Importing video with a weird aspect ratio
  • Importing video with a weird aspect ratio
    Posted by Inbar Marmelshtein on October 1, 2018 at 10:38 am
    Hey guys,
    I am making a video essay about a film so I linked AMA and then transcoded the part of the file of the film I need, the problem is that the original video’s ratio is 1080×800 (when you view it as a film it obviously just have black bars), so it starched as I linked the file. Is there anything I can do other than resizing the video in avid, so I can keep the original aspect ratio? If the only way is resizing, is there any formula or something so I can get the original aspect ratio, or should I just eyeball it?
    Thanks a lot!
    Pat Horridge replied 7 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    October 1, 2018 at 7:03 pm
    OK…open the Source Browser….FILE>INPUT>SOURCE BROWSER. Now, you can either LINK to the footage, and it won’t change anything. Or, you can IMPORT…and in the sprocket menu lower left right next to IMPORT, you can select DO NOT RESIZE SMALLER IMAGES. That should keep the same dimensions.
    Shane
    Little Frog Post
  • Pat Horridge
    October 2, 2018 at 5:49 am
    Frame flex
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
