Activity Forums Avid Media Composer Importing video
  • Importing video
    Posted by Amir Abed on February 18, 2015 at 6:52 pm
    Downloaded Media Composer 8 free trial. I’m having trouble importing video. I get an error message when opening the application.”No media can be written to any mounted drive. Please check write permissions”. And when I go to file import, import is grayed out. Working on a 2012 iMac no external drives. Thanks for any help.
    Mark Spano replied 11 years, 6 months ago 4 Members · 4 Replies
  • Eric Santiago
    February 18, 2015 at 8:01 pm
    Do you permissions to save to your internal drive?
    You can always use an external drive.
    If it doesnt see it, make a folder at top root named “Avid MediaFiles”.
  • Shane Ross
    February 18, 2015 at 9:21 pm
    Go into your SETTINGS, and in the MEDIA CREATION settings, first tab is DRIVE FILTERING. Make sure FILTER SYSTEM DRIVE is not selected…as well as LAUNCH drive.
    Or get an external drive. Best to put media on the external.
    Shane
    Little Frog Post
  • Amir Abed
    February 18, 2015 at 10:31 pm
    Thanks, I know I should have my media on an external but I’m just messing around not doing any real editing. But again thanks I’ll check media creation setting.
  • Mark Spano
    February 19, 2015 at 4:56 pm
    check it – it’s the first pinned topic in the Media Composer forum…
    https://community.avid.com/forums/t/101235.aspx
