Activity › Forums › Apple Final Cut Pro Legacy › Importing via Sreamclip
  • Importing via Sreamclip
    Posted by David Barrett on March 8, 2007 at 6:36 am
    I am using mpeg Streamclip to import DVD footage into a project. I choose “export to DV” and whilst the files load OK, the audio needs to be rendered. I presume this is because Streamclip makes the audio 32 bit and my sequence can only be 8 16 or 24. I can’t find any audio preference to change in Steamclip, is there a way around this ?
    Regard,
    David Barrett
    Melbourne Australia
    Bret Williams replied 19 years, 6 months ago 4 Members · 3 Replies
  • Paul Dickin
    March 8, 2007 at 8:08 am
    Hi
    Answered in this forum a mere 14 hours or so ago, or so…
    https://forums.creativecow.net/readpost/8/927267?
    “If you Export from Mpeg Streamclip using the Export to DV setting you get a .dv stream, as used in iMovie.
    What you need to do is Export to QuickTime, then choose the Compression setting Apple DV-PAL.”
  • Rafael Amador
    March 8, 2007 at 12:26 pm
    Hi David,
    Paul is pointing you the correct path. just to add, if you want to get the best from the DVD, don’t export it as DV. Choose a higher “intergrity” codec, 8b Uncompress for example.
    cheers,
    rafael
  • Bret Williams
    March 8, 2007 at 4:42 pm
    Unless of course you’re editing in DV as he is and don’t want to rerender you uncompressed clip as dv yet again in the timeline.
