Activity Forums Apple Final Cut Pro Legacy Importing using a DVD player
  • Importing using a DVD player
    Posted by Rolanda on February 27, 2006 at 3:54 pm
    I’m trying to import video using a dvd player. I have footage in the Log and Capture window, however, when I hit Capture Now. I keep getting “Capture now has reached the end of tape. All existing footage …” how do I get the video footage in for edit?
    Rolanda
    Rolanda replied 20 years, 6 months ago 6 Members · 11 Replies
  • 11 Replies
  • Bouncing Account needs new email address
    February 27, 2006 at 4:23 pm
    You must switch the Control setting to “Non-controllable Device”.
  • Rolanda
    February 27, 2006 at 4:25 pm
    It’s not on Non-Controlable Device. It’s on Firewire NTSC. Im using final cut pro 5.
  • Steve Eisen
    February 27, 2006 at 4:32 pm
    No DVD Payer can be controlled via Firewire INTO FCP. Some DVD Recorders (not many) have been known to OUTPUT via firewire.
    You will need to use Capture Now or rip the disc. Hopefully not a Copywrited Disc!.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Rolanda
    February 27, 2006 at 4:34 pm
    It’s not on “non -controlable devices” it’s on firewire Ntsc. So what do i do now?
  • Rolanda
    February 27, 2006 at 4:49 pm
    Right, I’m using capture now. Yet it’s still giving me this message “Capture now has reached the end of tape…”
  • David Bogie
    February 27, 2006 at 4:59 pm
    Since you have posted this to at least two FCP forums, be sure and go back to each of them and close the threads.
    bogiesan
  • Jeremy Garchow
    February 27, 2006 at 6:05 pm
    Change it to non controllable device!
    February 27, 2006 at 6:11 pm
    [JeremyG]
    Change it to non controllable device!”
    Give UP, Jeremy.
    She just WON’T do that.
  • Jeremy Garchow
    February 27, 2006 at 6:16 pm
    Got it! Sorry to butt in there like that. I should know when to keep my mouth shut. 8^)
    Jeremy
  • Thew
    February 27, 2006 at 8:28 pm
    I sure its not able to syn up with Firewire..which is the biggest proble.
    Id try different capture settings, also try trashin your preferences..
    You might be out of luck though, I know alot of boxes out there with firewire ports..
    My cable box has one, but I dont think FCP will synce up with it properly..
    I have the same problem with an old JVC camera wont sync..
    Only other suggestion is go through a break out box of some sort..AJA pinicle.. go Svideo in and AV and then go directly into you system
    GOOD LUCK.
