Activity Forums Adobe Premiere Pro Importing transparent GIF/PSD issues
  • Importing transparent GIF/PSD issues
    Posted by Deniz Ulker on April 10, 2015 at 1:29 am
    Hey forum (my first post here so pls be kind:) )
    For a video project I want to embed transparent gifs over an existing video. For this I had to remove the background of the images first in Photoshop (as explained here) and exported them as GIFs and kept the PSDs around just in case. However when I import the GIFs in premiere I always end up with a white background instead of transparent. (Viewed somewhere else like a browser they are transparent) So I switched to importing the PSDs instead, but another mystery is that some of the layers don’t show up in Premiere at all, but they are there in Photoshop. How come this is the case?
    Also, another quick question: When I choose a number of clips from say Video Track 3 to copy and want to paste them right after where the first batch ends on the same track, its always pasted on the Track 1 instead. If you could help me with this too I would appreciate a lot, thanks.
    Deniz Ulker replied 11 years, 4 months ago 2 Members · 2 Replies
  • Trent Happel
    April 10, 2015 at 4:04 am
    When you import the PSD, do you see all the layers in the Import Layered File dialog? If so, did you select Individual Layers and make sure to select all the checkboxes for each layer?
    To paste to a specific track, make sure you have targeted the desired video and audio tracks. By default, V1 is targeted. Select/click V3 (it should highlight and you’ll also see a tooltip mentioning track targeting) and deselect V1. Paste should now go to V3.
    Trent Happel
    Adobe
    Premiere Pro
  • Deniz Ulker
    April 12, 2015 at 1:06 pm
    Thanks for the reply Mr Happel,
    After I posted this I did a little bit of research and the answer came up in adobe forums; namely exporting the gif as a .mov file and importing it that way helps with transparency. As for your question, no I did not see all the layers either in the import box or after they are all in the bin. I have no idea why, as in the psd everything seems to be in order.
    Thanks for the pasting tip as well, helped a great deal.
