Activity Forums Apple Final Cut Pro Legacy importing thu final cut vs imovie…
  • importing thu final cut vs imovie…
    Posted by Teamtigerpaw on September 12, 2007 at 9:30 am
    Hello all,
    I for the life of me cant import in final cut pro studio.
    “Capture encounter a problem reading the data on your source tape this could be a problem with the tape. Capture has been aborted and your clip has been save”
    I will get about a second into it and get that message.
    I have Sony HVR-Z1U and have it on FireWire NTSC setting. I can control the camera thur the mac. I am saving to the internal drive and am justing hitting the capture now button.
    Here is my question. I can get the footage imported thur Imoive. Does it matter if i import the footage thur imovie?
    Will that footage look any different? Time is a total factor. I have a few projects some HD some standard.
    If not what should I do differently to import the footage.
    Thank you for your help.
    B
    13 replied 18 years, 12 months ago 3 Members · 5 Replies
  • Tom Wolsky
    September 12, 2007 at 11:56 am
    What settings are you using in FCP?
    Material captured in iMovie is in the wrong format and needs to have the audio rendered. It also has no timecode and reel information so it’s not recapturable.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Teamtigerpaw
    September 12, 2007 at 12:25 pm
    Thanks Tom, I ended up figuring it out. As you guessed it was all in the settings. I ended up monkeying with them and it imported.. I keep getting this warning everytime i put a clip in a sequence
    “Warning- This clip does not match this sequence’s settings.
    For best performance your sequence and External Video should be set to the format of the clips you are editing
    Change sequence settings to match the clips settings
    No Yes ”
    The project i am working I am not using the sound off the Tape.. but I am going to be in the future. Do you know what is up with that warning and what I should do about it? I watched some of the clips and it seemed to line up fine. I am guessing its a either yes or no, or I should change something somewhere.
    Thanks again for your first response. I really apprenticed it.
    B
  • Tom Wolsky
    September 12, 2007 at 12:40 pm
    Your sequence settings don’t match your clip settings. Edit a clip into the timeline, say yes to the dialog, and FCP will fix your mistake for you.
    All the best,
    Tom
  • Teamtigerpaw
    September 12, 2007 at 1:16 pm
    Thanks Tom, your the man!
  • 13 Create COW Profile Image
    13
    September 12, 2007 at 5:01 pm
    [Teamtigerpaw] “I am saving to the internal drive and am justing hitting the capture now button. “
    You should also not be capturing to the internal system drive. It has enough to to do already running the OS and applications. You will get dropped frames.
