Activity Forums Adobe InDesign Importing Text with Oversized beginning letters
  • Importing Text with Oversized beginning letters
    Posted by John Perez on February 8, 2019 at 9:57 pm
    For some reason the first letters or numbers on the left side of my text box are hugely oversized! Why could this be happening? I uploaded a screen cap of the problem but I don’t know if you can see it?
    HP Intel(R) Core i-7 CPU
    950 @3.07G 3.07
    RAM: 8 Gigs
    64 Bit Op System
    As always thanks so much to you guys…Johnny In Orlando
    Kalleheikki Kannisto replied 7 years, 6 months ago 3 Members · 2 Replies
  • Francois Pénzes
    February 11, 2019 at 9:56 am
    Hi John
    No links and no capture.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Kalleheikki Kannisto
    March 6, 2019 at 4:05 pm
    That is an initial capital (or “drop cap”). You can turn it off in the paragraph designer for that style. Just set the number of lines to 1.
    A less likely scenario, it is a character format that has been applied in Word (or whatever the files is sourced from), in which case you can modify or, most likely, just delete that character format. May have to remove overrides in the paragraph panel afterwards to get fully rid of it, as it may remain as a style override.
    Senior Graphic Designer
