Activity Forums Adobe Photoshop Importing text drop shadows to FCP
  • Importing text drop shadows to FCP
    Posted by Rick Diamond on May 3, 2005 at 5:05 pm
    I’m having trouble importing text created in Photoshop CS into Final Cut 4.5. The text itself comes through fine, but any glows, drop shadows, etc., don’t make it unless I merge layers. Is there something I’m missing? I’d like to be able to keep the layers seperate in FCP.
    Rick Diamond
    Rick Diamond replied 21 years, 4 months ago 2 Members · 2 Replies
  • Bobby Walker ii
    May 3, 2005 at 8:34 pm
    Your doing nothing wrong, it’s just that FCP doesn’t recognize layer styles. The only way to get them into FCP is to right click on the style button to the left of the name of the layer and select “create as layers”. This will rasterize the effects, however and keep them from being edited.
    Usually I’ll create my original graphic and then duplicate it and use the duplicate to create the rasterized layers and use that comp in FCP
    hth-
    bobby walker ii
    broadcast video COW
    G5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
  • Rick Diamond
    May 4, 2005 at 12:09 am
    thanks Bobby, I’ll give it a try.
    Rick
