Activity Forums Apple Final Cut Pro Legacy Importing Stills Longer than Two Minutes
  • Importing Stills Longer than Two Minutes
    Posted by Martin Nelson on November 24, 2010 at 8:59 pm
    Hiya,
    I’ve got a tiff with an alpha channel I’d like to import to use as a bug. The default import for a still (it seems) is 00:02:10:00. Is there a way to tell FCP to generate a longer duration or another way of extending this for the full duration of my sequence without having to overwrite it multiple times?
    Thanks and Happy Thanksgiving Y’all,
    Martin
    2 x 2.26 Ghz Quad-Core Intel Xeon
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
    Avid Media Composer 4.0.2.20
    Martin Nelson replied 15 years, 10 months ago 3 Members · 4 Replies
  • Rafael Amador
    November 24, 2010 at 9:24 pm
    Hi Martin,
    Double click the still to open it in the Viewer, and change the duration there: on the left corner box.
    rafael
    http://www.nagavideo.com
  • Paul Jay
    November 24, 2010 at 9:46 pm
    Change still duration in the preferences.
    All stills you import AFTER will have that default length.
  • Martin Nelson
    November 24, 2010 at 11:06 pm
    Exactly what I was looking for. Thank you Rafael
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
  • Martin Nelson
    November 24, 2010 at 11:12 pm
    User Preferences>Editing>Stills/Freeze Frame Duration appears to be just for setting the marks in and out on a freeze frames. For example, it’s default setting is 10:00 and if I freeze a clip I get a 2 minute freeze frame with a ten second in to out.
    Am I looking at the wrong setting Paul?
    Martin
    12 GB RAM
    OS 10.5.8
    ATI Radeon HD 4870
    FCP 7.0.2
    Quicktime 7.6.6
