Activity Forums Adobe Premiere Pro Importing stills for a timelapse (PP CS6)
  • Importing stills for a timelapse (PP CS6)
    Posted by Ryan Mcguinn on October 2, 2014 at 5:56 am
    Okay so I need some help importing some stills for a timelapse in Premiere. Normally with my camera I open premiere, click import, find the stills I want and check the box that says “image sequence.” Normally a very easy process. But, I downloaded an app on my s4 called LapseIt and it doesn’t seem to be so easy. The name of the files arent numbered in any numeric order so PP doesn’t know it’s a sequence. I tried copying all 800+ images into premiere but it didn’t automatically turn the stills into a video as it usually does. Anyone have any ideas on how to get this done? You can render through the app, but it will turn out much better with PP. Thanks for your help 🙂
    Daniel Tyukodi replied 11 years, 11 months ago 2 Members · 1 Reply
  • Daniel Tyukodi
    October 2, 2014 at 1:08 pm
    you should rename the files.
    ex: use total commander multi-rename tool
