importing still photos into final cut
Hello
I am a stop-motion animator, taking large digital still images into Final Cut Pro to edit. There are several problems that seem to arise each time I make an animation. First, when I bring in images that I have resized as 720 by 480 in Photoshop, to animate in my FCP time line, FCP stretches the images. I know that I am saving the images with square pixels and then changing the project setting for square pixels, but no matter how I save the pixels in Photoshop the images open in FCP with the .9 aspect ratio. Is there a way to change the pixel aspect ratio default that FCP uses when it brings in stills? My camera takes images at 1936 x1288 which is a 3:2 aspect ratio, so why are they getting distorted or stretched? I’m frustrated because I know that there is a way to do this right. Is there a really good resource online or in a book for solving these problems? Also I am having a “fuzziness” or slight interlacing look that appears periodically in the images, do you know what causes this?
thanksjjr
