Activity › Forums › Apple Final Cut Pro Legacy › Importing Still into FCP
  • Importing Still into FCP
    Posted by Jess Reynolds on June 28, 2012 at 7:41 pm
    Hi there
    I have a number of time lapses shot on the 5D that I need to import into FCP. Is there a way to set the duration of the stills (like you can in avid) so that when I import a folder of stills they are only 1 second long. Right now they are 10 seconds long.
    Many thanks
    Jess
    Mark Suszko replied 14 years, 3 months ago 2 Members · 1 Reply
  • Mark Suszko
    June 28, 2012 at 8:24 pm
    Yes, you set this in user preferences:
    see here it is set to ten sec. change that to one second, use a brand new bin for each set of stills. Stills should be in the 0000 format, so image one is 0001, then 0002, etc. or else they can get out of order in the timeline.
