Activity Forums Apple Final Cut Pro Legacy Importing Still Frames at 1 Frame Each?
  • Importing Still Frames at 1 Frame Each?
    Posted by Richard Boddington on January 16, 2013 at 4:54 pm
    I have a folder with 101 .png files that I want to import into FCP. I can import the folder but upon importation FCP changes each frame to 10 seconds vs 1 fame. This is useless to me as I want to re-export the folder as a 101 frame QT movie.
    I have been through every setting I can find, but I can’t find the setting to change this to 1 frame vs what appears to be a default of 10 seconds.
    Anyone have any ideas where this setting change is hiding?
    Richard
    John Benson replied 13 years, 2 months ago 7 Members · 6 Replies
  • Rafael Amador
    January 16, 2013 at 5:02 pm
    Look on the FC Preference “Still duration”.
    rafael
    http://www.nagavideo.com
  • Massimo Alberto croce
    January 16, 2013 at 6:56 pm
    Go to users preference>editing and change the default duration of still to 1frame
    Massimo Alberto Croce
    Video Editor, Colorist, Pro Tools Editor
    massimoalberto.croce@gmail.com
  • Mark Suszko
    January 16, 2013 at 10:24 pm
    Also, all the frames you made need to have the same number of digits in their names. i.e. if you made 300 frames, the first frame needs to start as 001, not just “1”. Otherwise, the files will get scrambled.
  • Richard Van harderwijk
    January 17, 2013 at 8:30 am
    re-import the stills after you have changed the setting
    grtz
  • Tom Matthies
    January 17, 2013 at 2:31 pm
    You can also make a sequence using just Quicktime Pro if the frames are numbered on order. Just point it to the first frame in the sequence, tell it what format to make and go. Very simple and easy.
    E=MC2+/-2db
  • John Benson
    July 21, 2013 at 3:19 pm
    Any luck with this? I have the setting in my prefs to import for a duration of 0.125 but I still end up with a 10 second import (after attempting a re-import, of course). FCPX 10.0.8
